bluemonkeyflyer
- Jan 20, 2011
Hi BMF/Justin!
Hope you're doing fine!
I'm still using the BMFv3 and I wonder what your favourite mod might be?
Do you consider the Balsa Wood Mod to be an upgrade? If so I definitely have to get some balsa wood first thing tomorrow morning.
Keep up the great work!
Best,
Alex
Hi Alex,
Doing great, thanks.
I don't currently have a DBVv3 on hand. We all know audio memory is ephemeral...so, I cannot say for sure that the Balsa Wood and All Paxmate mods are better, or not. I can say they're easier to build and require fewer components. Based on memory, they're more similar than different.
I think these simple mods compete with more complicated modification configurations but the devil is in the (implementation) details. In other words, the only way to know is for each person to try them and draw their own conclusions.
nick n's MemFoam Mod is very good, too! I had the opportunity to listen to two sets built by nick n: one was more neutral and the second bass enhanced. I was able to compare them against each other as well as my rendition of his MemFoam mod. I'll post impressions in the "nickerfied" thread.
Best,
BMF/not Justin
