KneelJung
- Jul 3, 2010
Anybody have any cable replacement recommendations for a Fostex T50?
I've purchased a few V-Moda cables...they used to work great.
I've had to replace a few because they seem to fail if they're removed from the 3.5 to 6.5 adapter plug a little to harshly. The last 2 I bought though just started working poorly Bad connection between the cable, and the adapter. Not sure if it's the cable, or the adapter. I'm thinking cable, because the issue persisted when I changed the adapter.
They used to be like $11 too. They're twenty something now.
Tried one from Mediabridge, and it didn't work at all.
Anybody have any thoughts, or experienced similar issues with the V-Moda cable?
