mordy
- Aug 8, 2010
Hi R,
I cannot tell you if it will work in the Glenn OTL amp since I am not familiar with it. The 6SN7 draws 0.6A and the EL3N draws 0.9A. If the amp can use driver tubes that draw 1.8A it should not be a problem. A quad of EL3N would draw 3.6A which possibly is beyond the design parameters for driver tubes in this amp. You would have to check with the manufacturer if this is possible.
In the Elise amp we are using the EL3N as a direct substitute for the 6SN7 tube. I do not see the need for a dual EL3N as a driver since the results are so good.
The dual EL3N have been used as power tubes in the Elise with the same EL3N as drivers with very good results from what I have read. There are definitively sonic benefits from using certain dual power tubes, with greater drive,power and authority.
Personally, I have gotten excellent results from using dual 6BL7 power tubes. At this point I am very impressed, to put it mildly, by a dual set-up of 6BL7 and 6N7 power tubes. These two tubes draw 2.3A so they are compatible with any amp that uses 6AS7/6080 power tubes which draw 2.5A.
