abvolt
I agree it's very cool love to have a pair of those..
Use nothing but GEC 6as7s in my wa22.
Best sound of any power tube
i started using RCA 6AS7G on WA2 and they sound great, lot better than the stock GE 6080WC.
Jst one problem..it happened two times so far, once in left channel and once in right; Its a momentary noise peak that makes pop/jerk sound.
It comes thru at high volume and i'm beginning to think if it happens often it would affect my hearing.
Is this supposed to happen with these tubes? i did not have this issue with the 6080WC
Not normal. You might want to try turning the amp on and not listening for 20 mins until it has warmed up fully.
The RCA's are not expensive, might also try a different pair.
There is also a 6AS7GA tube at parts express that can be bought new inexpensively and these preform well:
http://www.parts-express.com/6as7ga-ge-jan-vacuum-tube--072-612
Cheers
Can anyone confirm these are legit GEC 6AS7G tubes
Something about the first picture just looks off.
Can anyone angle their GEC to make it look like that in the first pic?
Hi guys I'm looking into a Mullard CV 2964 6080 and I found two actually.
One displays a 1975 over the original box and the other a AJ1 R1F1 code on the glass.
The construction is the same.
What means the data code of the second one?
Actually, AJ0 is the first version. AJ1 represents revision #1 if you will:
On the left, AJ0 R7J = 1957. And on the right, AJ1 R7K1 = 1967
