hardstyler
- Apr 29, 2006
Hello headfiers.
What are the best settings in terms of sound quality for a setup like this? See my signature below.
Spitfire is a 24bit/96khz DAC.
Prelude soundcard is in Audio creation mode. Master sampling rate is 96khz and bit-matched playback is enabled. Is this even necessary if most of my music is in 44.1khz mp3 format?
Now the question is what settings should use in foobar2000. Should I even use DSPs or is that going to reduce sound quality?
When I use the resampler DSP and set freq. to 96khz I don't notice any difference in sound quality.
Any help with this will be appreciated because I'm a bit of a computer audio noob
Thanks.
![biggrin.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/biggrin.gif)
Thanks.
