Yeah or get Bathys as well, compare them. You can easily resell the Celestee at that price or even make a profitBag the Celestee now at that price and then wait a bit to get the Bathys as well or their next wireless offering
Focal Bathys Hi-Fi Bluetooth & ANC Headphones: Early Impressions
- Thread starter jude
- Tags
- focal focal bathys
This. I am extremely happy with my H95's but do enjoy the Focal house sound.I'm also interested in these... Although I've had my H95s for over a year now and it'd take a pretty big increase in sound quality and/or ANC for me to want to switch to a different bluetooth headphone, especially as I have the Stellias already for office use.
Benno1988
@MightygreySo maybe a silly question, can this bathys be used for gaming. For instance iracing? I always doubted about buying the audeze mobius but this looks like a better choice. Is it ok for gaming?
Mightygrey
I plugged the Bathys straight into my Xbox controller - it worked great playing PUBG.So maybe a silly question, can this bathys be used for gaming. For instance iracing? I always doubted about buying the audeze mobius but this looks like a better choice. Is it ok for gaming?
adeeb
- Nov 13, 2016
I’d be interested in feedback on how it sounds wired directly via usb to an iPhone playing hi-res through Roon Arc vs using a high quality portable DAC/amp (say in $500-$700 range) attached to iPhone w/ Arc.
I’m sure it isn’t a fair comparison given the price gap, but how audible is the difference? The sound direct may even be better as the internals of the Bathys were tuned specifically for it.
Mightygrey
Probably no difference. The Bathys' DSP will be processing the analogue signal fed into it from the DAC/amp, which would probably be inferior to the Bathys' internal DAC in all likelihood.I’d be interested in feedback on how it sounds wired directly via usb to an iPhone playing hi-res through Roon Arc vs using a high quality portable DAC/amp (say in $500-$700 range) attached to iPhone w/ Arc.
Ansch
There's a question of how the Bathys handles the analog input from the external DAC. Does it go back through a A/D->DSP->D/A stage or is it simply A-A via its amp circuit? Either way it's not being driven directly from the external DAC/AMP.I’d be interested in feedback on how it sounds wired directly via usb to an iPhone playing hi-res through Roon Arc vs using a high quality portable DAC/amp (say in $500-$700 range) attached to iPhone w/ Arc.
Razza1974
Thanks, and can you use it wirelessly to the pc, does that sound great? My main use would be wireless when gaming and rowingI plugged the Bathys straight into my Xbox controller - it worked great playing PUBG.
flyte3333
Previously known as Em2016
- Jan 21, 2017
No measurements @jude ?
zadillo
- Mar 27, 2013
Wouldn’t a USB C to lightning adapter be simpler?Bathys USB-C cable termination - to -> USB-A adapter - to -> Apple lightning "Camera adapter" - to -> iPhone lightning port. Bulky and approximately $40 USD more on top of the Bathys' cost.
frix
- May 7, 2012
Check out resolves measurements @headphones.conmNo measurements @jude ?
flyte3333
- Jan 21, 2017
Seen it but want to see measurement on a different rig like Jude has
More data, better
Hamuraii
ddHiFi lightning to USB-C adapter its OTG certified and just works.
Check my signature and stop using the dirty camera dongle.
Waiting for a comparison between Bathys and PX8
Ansch
They're quite short lengths though right? So you'd then use a usb-c extension cable to your headphones?ddHiFi lightning to USB-C adapter its OTG certified and just works.
