roines1987
Oh yes. I have tried a bunch of different variationsI haven’t, but I’ll see if I can tonight.
Have you tried to first use the Mimi option and then EQ to taste after that?
stupid question: why do you buy dune, if you would cover it up? (I know the headband will change colors, but that's a part of the game, isn't it?)Has anyone found a good headband cover for the dune colorway?
If anyone is looking for a good headband cover for their Bathys, look no further. Just got this one in from amazon and they offer colorways that match both the OG colroway Bathys and the Dune: Amazon Link for Bathys Headband Cover
Here's how the light colorway looks on my new Dunes. Even fixed the slight hotspot issue I got on the top of my head without the cover.
No problem! It does its job well and actually improves comfort for me. Just may look a little nerdy on flights lol. I cut off the loop and the little branding label on mine and it's more subtle now.
To keep the headband from looking nasty, it does not cover up the cups that's pretty obviousstupid question: why do you buy dune, if you would cover it up? (I know the headband will change colors, but that's a part of the game, isn't it?)
would still buy another color.....covers looks silly - to me.... sorryTo keep the headband from looking nasty, it does not cover up the cups that's pretty obvious
Yeah that one looked good and was comfy. Improved the hot spot for me. Also the "silver grey" color matched well.
Good for you, I like the dunewould still buy another color.....covers looks silly - to me.... sorry
me tooGood for you, I like the dune
What brand is that?Yeah that one looked good and was comfy. Improved the hot spot for me. Also the "silver grey" color matched well.
https://www.amazon.com/dp/B0B2QSNYVJWhat brand is that?
I bought these sheepskin pads based on JML’s review. My priorities are comfort and sound in that order. Coming from the Clear MG and having heard the difference that the Dekoni pads (+properly made cable) made to these cans I was curious about the effect of the Dekoni pads on the Bathys. Given the Clear MG original pads are perforated cloth and the Dekoni Sheepskin pads are leather i wasn’t expecting as much of a difference / improvement given the Bathys pads are already leather / leatherette material.I think the Dekoni sheepskin pads are worth buying; they're an improvement over the stock pads in sound and comfort.
I've been comparing them to the stock pads for the past hour or so using familiar high-resolution classic rock files I've uploaded to Vox, via my iPhone 15 Pro and the Bathy's USB DAC. If I had to pick a short description to characterize the result of using the Dekoni pads, I'd say the sound seems cleaner and smoother overall, especially in the midrange (which has a bit more presence and clarity). The bass is also smoother; I think the Focal pads over-emphasized the bass and the upper bass and the lower midrange was a bit muddy. I don't hear any deep bass loss with familiar music having significant bass content, and the bass seems faster, cleaner, and harder-hitting. I don't hear any difference in the highs, but I do have age-related hearing loss and have compensated using Mimi at 30% (I did redo the Mimi equalization after listening to the Dekoni pads for a while, but the resulting graph looks the same as when I had the stock pads installed). The Bathys sounds closer to my Focal Clear than before (of course the Clear is open and the Bathys is closed).
And the leather pads are definitely cooler to wear than the artificial material of the Focal pads. There's no heat or sweat build-up at all. They're as thick as the Focal pads, even softer, and the replacement is perfect, simple, and secure. Just be sure that you orient them properly by matching the two cylindrical pins on the plastic mounting panel with the corresponding holes in the earpiece panel, and then gently push down around all of the circumference of the pad until you hear clicks from the rectangular tabs and don't see the edge of pad's plastic mounting panel. The clamping force seems to be slightly less than with the Focal pads, and more comfortable, so maybe the foam inside compresses more easily. I like them so much I think I'll get a spare set. Plus they smell nice!
Just to put in a plug for Vox: I can listen to all my uploaded music from their server, streamed via my iPhone to the Bathys at high resolution via the wired connection. Plus Vox has an outstanding built-in equalizer and several cross-feed options. For regular wired headphones and IEMs from my iPhone, I use my Questyle M15i as the DAC/amp.
