zunehdrocks
- Jan 25, 2014
Try checking out the shure srh440
Would you recommend those over akg 240s, grado sr60s, and audio technica m30x?Try checking out the shure srh440
I don't suggest m30x's, and the akg's imo are better than the grados. Definitely better build... Not anything extraordinary for build, but they still can take a drop and you can replace the cord. You can't swap out cords on the grados.Would you recommend those over akg 240s, grado sr60s, and audio technica m30x?
60i isn't versatile enough for your genres: it's good for rock, metal, pop, and vocals but not the rest.
I'm not so sure I totally agree with this. The SR60i is a pretty versatile headphone. If anything, it does rock and pop extremely well, and it does the rest just okay (but not bad).
The SR60s are a great open choice. Another good open headphone is the Sennheiser PX100. If you want closed, try the Martin Logan Mikros 90.
... Seriously, get the akg's. The midrange is bar none at this price from the cans I've heard.
I can't say much about the 240s or sr60s because I haven't heard them. The ath m30x definetly sound worse than the Shure srh440.
There are a few threads about the Shure srh 440 vs akg k240
http://www.head-fi.org/t/561261/senheisser-hd448-vs-shure-srh-440-vs-akg-k240-mkii
I think im gonna get Sony mdr7506s or v6s
