esdk
- Jul 28, 2010
Okay okay okay - I give up - you win
The product is the best! - buy it! - but there might be delays as the entire chip industri is overburdened for the time - so next tape role is in late september and maybe later.
If you want my answer to your "bold" question - which I know you don't
The ADUM will not provide better sound on a less noisy PSU.
If you like it that way - keep it that way - No mather if it is right or wrong. (Maybe you don't even know why) - just know that this will not apply to the situation of all other users.
Here is some info to short USB cables: (This is with the USB isolation)
The shortes cable has less resistence, hence more power available - we sell the USB plug also (I think you bought it - right?)
If a short USB cable/Quality USB cable makes the sound "better" - it can be the higher power or that the SPDIF is closer to the capacitors in the USB2ISO, that improves the SPDIF module.
If any of these two scenarios is true - the SPDIF module is poorly designed: - The SPDIF, you have, has external supply - hence lot of power available. Ensuring stable power in an audio module is a must for any engineer.
PS: If you want to learn more about USB - I can highly recommend a short version at http://www.usbmadesimple.co.uk/ums_3.htm
Still looking forward to hear more about the secret features of the ADUM4160
Best Regards,
Soren
Electronics-shop.dk
Best Regards,
Soren
Electronics-shop.dk
