Final SONOROUS III
Mar 5, 2022 at 8:33 PM Post #151 of 162
After looking at the poor quality and gauge of the wire going to the driver, I wondered how much of an improvement a better wire would yield.
Decided to change out the wire to 24 awg Mundorf silver/gold and Mundorf silver/gold solder. This wire and solder is notorious for a lengthy burn in time, I would guess it needs around 200 hours to burn in completely but already off the bat, its more resolving and detailed, more energy in the mids and treble, bass seems a little tighter.
Before and after, the after is the yellow and white wire.
Jun 14, 2023 at 8:16 PM Post #152 of 162
I think the Sonorous III with the stock pads are boring. Replacing them with the Final B type pads is a huge improvement. See the review at hifiplus by Chris Martens.
Jun 15, 2023 at 9:22 AM Post #153 of 162
Why would wire and solder need to ‘burn in’?
Jun 15, 2023 at 12:40 PM Post #154 of 162
Oct 11, 2023 at 11:56 PM Post #155 of 162
Well this thread has been incredibly helpful! Thank you @dougms3 , my pair of Sonorous III's really have needed a new pair of pads and your recommendation was a fraction of the price of the Final Audio versions. I'm super excited to get them. I may have to implement some of your other mods as well!
Oct 13, 2023 at 7:07 PM Post #156 of 162
When buying a new cable for the Sonorous III's do I need to get one with the special locking mechanism that came on the factory cable?
Oct 13, 2023 at 7:25 PM Post #157 of 162
If you open up the headphone, you snip off those locking tabs with a razor blade and use any cable you want.
Thats the first thing I did. This headphone is one of the easiest to take apart. If I recall correctly, it only has 4 screws and the driver section comes right out.
Oct 13, 2023 at 8:36 PM Post #158 of 162
Ok great! That's good to know. Is there a good quality budget cables you'd recommend for them? I ordered a new headband and that set of ear pads you recommended.
Oct 13, 2023 at 8:52 PM Post #159 of 162
Moon audio silver dragon is always good but I'm partial to the high end cables because I know what they can do.
Those ear pads are good and I've used them for alot of other headphones as well but grain of salt, they are tuned to my preference. Which is bass heavy. I've also tried pads with less meat on them and they're good too, just a matter of preference of what you prefer.
Oct 13, 2023 at 8:56 PM Post #160 of 162
I really like good bass and mostly listen to electronic music, so they sound like they'll be a good fit!
Dec 24, 2023 at 9:52 PM Post #161 of 162
These aren't that bad if you used the B type pads with them. See Chris Martens' review at hifiplus.
