- Sep 25, 2010
New thread for - Final Audio Design - F4100- Impressions/Reviews
29,800YEN = USD280*
*approximate price conversion at time of release
Bringing the driver unit closer to the ear drum, achieves an even more realistic, vivid sound quality. In order to achieve this in the F4100, we have meticulously downsized the housing with a design consisting of the minimum possible elements. Miniaturized to have a diameter of 5.5 mm, the housing is finished with hard aluminium-magnesium alloy anodic film. This also contributes weight reduction. Final’s unique method of using full-range balanced armature drivers across all models recreates bass tones with a fullness you would never imagine from the housing size. The cable is high purity OFC with detachable MMCX connectors. The earphone comes with an ear hook to prevent microphonics from the cable. This is one of final’s proud model, realizing sound quality and ease of use in a higher dimension. It tends to have a slightly warmer sound quality than the F7200.
Features
Housing design that minimizes the distance between the ear drum and the driver unit.
You can position the product to be at the back or at the entrance of the ear canal, and change the sound quality by choosing different earpieces.
You can also change the position of the earpiece. Enables the sound output to be at the very front face of the earpiece. This is also a way to adjust sound quality. With the sound output at the very front, you will be able to feel the sound being transmitted directly.
Full-range balanced armature driver unit
We have used an ultra small full-range balanced armature driver unit.
Aluminium machined high rigidity housing
We used an aluminium-magnesium alloy for the F4100 housing, which in turn is finished in a chic black anodic film exhibiting high hardness.
Choice of 2 types of earpiece
We’ve included silicone earpieces in 5 sizes and foam earpieces in 3 sizes. Achieve a perfect fit no matter how large or small your ear canal is. Sealing performance is closely related to how the bass feels, as well as soundproofing performance. This system enables you to significantly change the fullness of the bass or the soundproofing performance. The foam type in particular has soundproofing performance similar to noise cancellation earpieces.
MMCX Connector&Original high purity OFC cable
We’ve used high-precision MMCX connectors from a famous Swiss manufacturer.
The cable is high purity OFC. The PVC tubing has been chosen for its flexibility and has been finished with a rope-like texture to reduce microphonics.
Safe fit ring
The earphone comes with a safe fit rings so you can use your silicone earpiece safely.
Accessories
Main unit, Carrying case, 2 types of earpieces, Ear hooks, Safe fit rings, Cotton swabs
http://final-audio-design-directshop.com/fs/final/f-series/FI-F4BALD
29,800YEN = USD280*
Features
Safe fit ring
Accessories
