imackler
- Nov 17, 2008
Here:
Epic fail. Thanks for the reply! Sounds like that would be an awesome way to go if I can find someone to do help with the upgrade!
Here:
@ClieOS would you happen to know (perhaps in passing, from Fiio guys) if the X3 1st gen has a dual rail supply? Or just a single rail supply?
Still looking for other chips that might work.
...Supply voltage in X3 is around +/-5V ~ +/-5.5V....
It has been awhile since I measured it, but IIRC, it is dual rail +/-5V.
p/s: Found it, here it is:
Is its possible solder another DAC in it ?
