Can't hear much difference, maybe a touch smoother on certain tracks, I keep mine at level 3 for music listening and 0 for reviewing.
FiiO Q7 Portable Desktop-Class DAC and Headphone Amplifier Discussion & Impressions Thread
- Thread starter FiiO
You mean Level 2? There is only Level 0, 1 and 2.Can't hear much difference, maybe a touch smoother on certain tracks, I keep mine at level 3 for music listening and 0 for reviewing.
Sorry, yes, I mean level 2.You mean Level 2? There is only Level 0, 1 and 2.
gto88
- Dec 11, 2014
First listen after firmware updated, I am hearing crazy bass enhancement, any one hear the same?
Second harmonic regulation:I tried but I don't hear any difference. I kept it at the default which is Level 0. What about you?
It simulates the special distortion of tube amplifiers. The second harmonic that doesn't exist in the original signal is artificially increased.
Compared to level 0, level 1 adds more second harmonics. If comparing the numbers, the harmonic distortion is about 0.X% for level 2, about 0.0X% for level 1, and about 0.00X% when off.
Note: This function is only effective when the volume is high, for example: in high (or higher) gain mode, the effect will be more obvious when the volume is above 70.
Best regards
This is why I am hearing the effects in some tracks and not alwaysSecond harmonic regulation:
Best regards
Thanks for the information! However when you say simulating the special distortion of tube amplifiers, do you mean adding 'warmth' of tube amplifiers or the 'imperfections of a tube amplifier'?It simulates the special distortion of tube amplifiers.
I thought the 1.04 firmware was more 'dynamic' but I could be biased because I tested the Q7 in the older firmware for 4 hours when I was at the store. I was testing with IE 600. With the new firmware, I do prefer the bass using the stock single-ended cable and single-ended side of the Q7. The balanced side is very clear and fast. Maybe that caused the bass to be 'colder'?First listen after firmware updated, I am hearing crazy bass enhancement, any one hear the same?
Dear friend,Thanks for the information! However when you say simulating the special distortion of tube amplifiers, do you mean adding 'warmth' of tube amplifiers or the 'imperfections of a tube amplifier'?
The special distortion of the tube amplifier, simulated by adding second harmonics manually that do not exist in the original signal.
Best regards
ApaucalyptiK
I just bought a 33W GaN USB C+A wall charger and USB C to DC adapter, it's very compact for travel, works like a charm with the Q7 DC mode and it only cost ~10 bucks for the charger + adapter
https://fr.aliexpress.com/item/1005004708545279.html
https://fr.aliexpress.com/item/1005004574709951.html
rumsky
Customer review:I just bought a 33W GaN USB C+A wall charger and USB C to DC adapter, it's very compact for travel, works like a charm with the Q7 DC mode and it only cost ~10 bucks for the charger + adapter
Failed in 2 weeks... Activates the PD for 1-2 seconds and goes back to 5 V.
What will happen to Q7 when the supply voltage is 5V?
ApaucalyptiK
My guess is it would be underpowered so the battery would kick in.Customer review:
@FiiO what do you think ?
Dear friend,My guess is it would be underpowered so the battery would kick in.
The 5V DC power supply is not compatible with Q7. When connecting it to the Q7, the Q7 will work like not conneting to power supply.
Best regards
Are you meaning the sound in general is different or specifically with the second harmonic feature ?
In respect of M11 Plus - upon reading a conversation between guys discussing the sound improvement with a new firmware that I could not hear I queried FiiO on these forum about whether they would or even could alter the sound with the firmware and their response was:
Dear friend,Hi Fiio,
Is there anything in the 1.0.8 update for the M11 Plus LTD that would change the sound in any way, and from all outputs apparently, including coaxial ?
Thank you
No, we will not change the sound via firmware update.
Best regards
I see no reason why that would be any different on the Q7 versus any other device. I am not sure how you A/B test for subtle changes when you have to update the firmware in between times, unless of course you have access to two Q7 with different firmware and an A/B switch set up.
In respect of the "single ended side of the Q7" versus the "balanced side" that you mentioned, are you aware that the single ended output is simply half the balanced amplifiers and not an entirely different circuit ? The positive of each channel is used along with a return to ground rather than the positive and negative for each channel, the negatives are left floating in that application, the circuitry is the same with the only difference being the total power output.
The output impedance of the single ended output will be lower so that might have an effect on the sound if using very low impedance IEM, more than the difference in power would I would venture.
I stand to be corrected if any of the above can be shown to be technically inaccurate of course.
ApaucalyptiK
Thanks, that's what I thought, so no worries @rumskyDear friend,
Best regards
Total: 11 (members: 1, guests: 10)
