[FiiO M17] Dual ES9038PRO, dual THXAAA-788+, dual power supplies, 9200mAh battery, 2 volume control modes
Mar 8, 2024 at 9:33 AM Post #5,672 of 5,696
Question for someone smarter than me: how do you delete albums successfully? I've removed some and they still show up in the FIIO Music player...
Thanks.
Mar 8, 2024 at 11:03 AM Post #5,673 of 5,696
Thanks.
Not smarter than you but have you rescan it?
Mar 12, 2024 at 4:23 AM Post #5,675 of 5,696
Yes, I did a full rescan.
What seems to be happening is that the albums are removed from the Albums view, but not the Genres view.
Dear friend,
I am sorry that I failed to reproduce the problem.
Please check:
1. Are you using the latest 3.2.0 FIIO Music app? If not, please try to update it first.
2. If you don't mind, please reset the database from the setting menu of the FIIO Music app, then rescan again for check?
Best regards
Mar 13, 2024 at 12:25 PM Post #5,676 of 5,696
Dear friend,
Please check:
Best regards
Resetting the database worked. Thank you!
Mar 13, 2024 at 12:52 PM Post #5,677 of 5,696
Good evening,
I have this weird behavior from my M17 that I don’t think should be normal.
If I have the DC charger connected with the DC/Bat switch set to DC, whenever I connect a USB C to the USB 3.0 port, be it an external USB hub to have more ports and ethernet, an external memory, a hardrive or anything other than a fast charger, the DC input gets overriden and the battery starts to drain. The ultra high gain mode is still active so the DC input it’s still recognized just not used anymore apparently. It doesn’t matter if the option to disable the battery charge is on or off, the battery still gets drained. If the option was on, the battery will start drainning, if the option was off and the battery was charging via DC, as soon as the USB C 3.0 gets plugged the battery will stop charging and start discharging. The only way to avoid this is to connect to the USB C 2.0 port, which is less than convenient since I loose transmission speed for my LAN from 1Gbps to 250Mbps, or if I connected a USB hub, to connect a fast charger to the hub.
I know that the USB 3.0 gets priority over the DC input when a Fast charge input is derected, but this is not the case. If I connect a Fast charger to the USB 3.0 it works as it should taking over the DC input and starts the fast charge (which in my opinion should not have been designed like this, the DC should always have priority over the USB C 3.0, the switching should be a configurable option).
But it makes no sense to take over the DC input every time anything is connected to that port, even if it’s not a fast charging thing.
Is everyone else having this issue or is it just me?
Regards.
Mar 16, 2024 at 2:21 AM Post #5,678 of 5,696
Good evening,
Regards.
Dear friend,
When you use the USB 3.0 as output port, you can not use the DC charging. The USB 3.0 and DC port can only be input or output at the same time. When the USB 3.0 is connected to the USB devices, the M17 will be forced to supply power to USB devices and cannot be charged at this time.
Best regards
Mar 16, 2024 at 3:03 AM Post #5,679 of 5,696
Dear friend,
Best regards
Hello,
Thanks for the answer, I suspected as much when I connect a device that needs to be powered by the M17, such as a USB hub, USB stick or a hard drive. My problem is that I have the same discharging issue when using the USB C 3.0 in USB DAC mode connected to an iPad or a PC, which both of them have their own power supply. In this case the M17 should not discharge, right? In my case it still discharges.
Regards.
Mar 18, 2024 at 5:59 AM Post #5,680 of 5,696
Hello,
Regards.
Dear friend,
1. Is the M17 connecting to the DC power supply?
2. Which switch is selected in the M17? BAT or DC?
Best regards
Mar 30, 2024 at 10:43 AM Post #5,681 of 5,696
Question: I noticed I had an album without cover art, so I replaced the .FLAC files with ones that had the cover art. I then had the FIIO music player rescan all folders but it didn't update the cover art (it still is blank).
Do I need to reset database for this situation?
Mar 31, 2024 at 9:44 PM Post #5,682 of 5,696
Dear friend,
Yes, please try to reset the database and scan again for check? If the problem remains, the cover art you added is the embedded or external cover?
Best regards
Apr 2, 2024 at 8:25 AM Post #5,683 of 5,696
Dear friend,
Best regards
I reset the database but the cover art did not appear. It was embedded. I then tried replacing the art and it worked fine.
What should I expect in the future when adjusting cover art or meta-data: should I always reset the database or does the app recognize when a file has been modified? Resetting the database takes a while (I have 12000 songs) and I would hate to lose playlists and favorites.
Thank you!
Apr 3, 2024 at 12:48 AM Post #5,685 of 5,696
@FiiO
I cannot install the latest FiiO app via google play store. Neither on my M17 nor on my M11 plus. Any ideas? In addition, I cannot deinstall the app, because of non-root permissions.
I just attempted to update on my 15S and could not.
