scarfacegt
- Nov 4, 2010
Whats the difference beetween lc an ls cable? Want one to my fiio fh7.
my LC4.4D is getting more stiff after the Y-split to the iems.. its getting worse over time .. is this normal? out of the box it was very soft .. meanwhile its really pretty stiffThe LC-RE consists of three kinds of wires – Furukawa monocrystalline copper, gold-plated monocrystalline copper, and pure silver.This three-precious metals cable improves on the entire spectrum of sound frequencies – you will hear robust and atmospheric bass, soothing and lush vocals, as well as extended and resonant treble. The LC-2.5/3.5/4.4-D cables adopts specifically, monocrystalline pure silver instead. This means less loss when transmitting audio signals over the cable, so that significantly more details are resolved and for a purer audio experience compared to silver-plated copper and even other typical pure silver cables.
And due to individual preferences, you could read the professional reviews and comparisons, as well as try out by yourself.
Best regards
LC mmcx and LS is 2pins , for the FH7 you will need the LCWhats the difference beetween lc an ls cable? Want one to my fiio fh7.
Dear user,my LC4.4D is getting more stiff after the Y-split to the iems.. its getting worse over time .. is this normal? out of the box it was very soft .. meanwhile its really pretty stiff
Yes.Thanks Fiio. I get an idea of the concepts. One technical question, are the wires individually insulated in the LC-RE as they are in the LC-xD? I suppose that insulation must pay great results in the LC-xD. It´s a very important design issue.
You can always get an adapter to make the 2.5mm balanced into a 3.5mm unbalanced plug.So i managed to order the lc 2.5d and fiio btr5.But not sure if the cable is woth it? The btr5 have balanced output.But i also have an dragonfly cobalt with mqa.But the cobalt doesnt have balanced output.Then i have to switch cables now an then.And i dont like that due to damage the iems/cable.
Any thougts about this dillema?
Tnx for reply That sounds like an option.Does it have any drawbacks? Soundquality?
Dear user,Hey guys, i just bought a LC-4.4D(MMCX) cable, it is very well built.
But it is behind the ear and not too comfortable, i can remove the plastic foil but there is a hard piece of bent plastic next to the mmcx connector, is it possible to remove it without damaging the cable so i could wear it straight down?
@FiiO, please make cable straight and leave the option of wearing them behind the ear to the buyer.
are 4.4/3.5 plugs interchangeable? (modular/switchable)FiiO LS-2.5D/3.5D/4.4D High Purity Sterling Silver Litz 0.78mm 2pins Balanced earphone replacement cable is now available in Aliexpress:
https://www.aliexpress.com/item/4000971671673.html
