Fiio FT5
Feb 21, 2024 at 5:28 AM Post #316 of 390
After a few weeks with my new FT5, I'm looking for a new headphone amplifier.
Maybe you can recommend one to me?
Since I want to operate a second headphone with a different impedance in parallel, it should have 2 adjustable outputs. Unfortunately, a LakePoeple G105 has too few inputs and no DAC.
So far I have used an Oehlbach XXL DAC.
Feb 21, 2024 at 5:45 AM Post #317 of 390
Topping A70 Pro
3 independent (volume and gain) headphone outputs: 2 balanced & 1 SE.
Feb 21, 2024 at 7:14 AM Post #319 of 390
You asked for amplifier recommendations.
What you seem to be after is an AMP/DAC combo.
I don't know of any with independent headphone outputs. Multiple, yes but not independent / switchable.
Feb 23, 2024 at 4:02 AM Post #320 of 390
You're right.
I'm looking for an AMP/DAC with 2 headphone outputs that can be adjusted so that I can listen to the FT5 and the FT3/350 at the same time as my wife.
The volume adjustment could also be done with “balance”.
Feb 26, 2024 at 1:47 AM Post #322 of 390
Its really a fiio K7 problem solved.
Are the headphone outputs switchable with independent volume and gain settings or is the signal alway "on" in every output ?
Feb 27, 2024 at 1:47 AM Post #323 of 390
Its alwsys on, and u will not find any headphone amp under like 1000€ or more where u can independently manipulate the balanced and single ended outputs. When i watching movies with my wife i use a mackie hm4 headphone splitter/amplifier so we can use headphones and can control the volumes independently with the knobs for each headphone. But its first of all a studio device, not a hifi although maybe this is what u searching for, its very cheap and i dont hear any drawbacks in audio quality vs the k7, weird. Oh and its only a single ended with 6.3 plugs.
Feb 27, 2024 at 3:25 AM Post #324 of 390
Mar 7, 2024 at 10:49 PM Post #325 of 390
Just how proprietary are the cup connections? Would I be able to use other cables with it, more specifically my Meze copper 4.4mm balanced cable? Is the fitment/clamp tight enough to do some head bobbin without them sliding off my head?
Mar 7, 2024 at 11:11 PM Post #326 of 390
They are just 3.5mm and the clamp is good without being too tight.
Mar 7, 2024 at 11:13 PM Post #328 of 390
Thanks buddy. I read a review stating that they are twist lock connections.
I read that somewhere too and I asked around as that was a concern before I bought them. But they are 3.5mm and use my Hart cables like the rest.
Mar 17, 2024 at 8:49 AM Post #330 of 390
Hello,
Does anyone know if Fiio sells replacement ear pads for the FT5. I checked their Aliexpress store but they only sell the cable as a spare.
Regards.
you can contact us by support@fiio.com and we can help you. it works any parts of our products.
