jeromeoflaherty
They provide a bunch of different adapters, so you swap the plug on the end of the cable - it is a very clever design - if you are swapping from 4.4mm to 3.5mm just make sure you align the 4-pins when you unscrew and screw in the alternative adapter.I just got my FT5 and the cable has the wrong plug on the end. Can’t use a 1/4” adapter to use in my amps.
