KLJTech
- Aug 12, 2008
I have a new Fiio E11 that will be arriving in the next day or two and for the most part I'll be using it with Klipsch Image X5's when I'm on the move. I've been reading reviews here about the amp but I'm still not so sure what is the best Power and Gain setting for the X5's.
Should High Power and Low Gain work fine with those IEM's? At home if I'm not in my office to use my desktop HP amp I'll be using either my Grado 325i or the AKG 701's......was hoping that I could use the High Power and then just switch over to High Gain when using the full sized headphones then there is no need to crack it open every time I switch to the home cans.
Thanks in advance for any help you may be able to provide!
Take care.
Take care.
