- Sep 3, 2006
Hmm, well, I obviously can't hear with your ears, so all I can do is make guesses. From what you have said, it seems to me that the E10K is probably working as designed. I can't quite decide whether the core issue is that you simply do not like how the AKG sounds, or if the E10K is simply not making the level of improvement you expected. The E10K is really not a powerhouse amp. It provides a modest gain that works OK with a broad range of headphones. Using a handy spreadsheet I found on google, the K612, at 120 Ohms and 101 dB/V, works out to 91.8 dB/mW. That's really not very sensitive. However, it's not clear to me whether a different, more powerful amp, for example the Schiit Magni2, would make much difference in the areas of the sound that you have issue with. I suspect not. IMHO, an amp makes much less impact on headphones than most audiophiles will admit. Or, the K612 just might not be the right headphones for you. Just because they cost more doesn't mean you will like them more. I have heard very expensive headphones that I really disliked (*cough* Grado GS1000 *cough*) - but I know that many other people love them. *shrugs*
