This new FIIO K19 "balanced" amplifier is interesting, but is it fully balanced?:
- Balanced XLR4 headphone output - has
- 4.4mm balanced headphone output - has
- Balanced output 2x XLR - LineOut - has
At the Fiio booth for Can Jam Singapore 2024, I tested 2 upcoming IEMs.
First up, we have the Fiio FD15, a single DD that should retail for around $150 - 200 USD.
This sounds very safe, U-shaped with safe upper frequencies. Timbre is organic and very natural. Technicalities are quite good for a single DD with nice sub-bass rumble.
n the second photo, we have the Fiio FA19. This is a 10 Knowles BA set, I think it should retail at sub $2K USD and is one of their higher end offerings.
The FA19 has 2 tuning switches, and is neutral bright, very technical beast. Transparent and clean sonics. Their previous FX15 was a bit hot in the upper mids, but this one is safer in that region, but more technical to boot.
I saw the fuse of R9 is placed at the iec socket which is easy to upgrade. I found no on the K19 iec socket. is the fuse moved inside? or no fuse at all? what is the spec of the fuse?
@FiiO why don't you try to use 2 in parallel buf634a (in optimal thermal pad package) output configuration instead of OPA926 to TPA6120A2 switchable output for new devices? Switchable BW biasing in this configuration should be a win! There is even no need to use series resistor to provide very small internal impedance due to buf634 has internal thermal protection.
(De)motivation: I'm little frustrated and tired to see hyped THX AAA 788+ measurements, where distortions in non-desktop supply mode (OPA926 output?) drammatically increased on 10 kHz and above...
(TPA6120A2 is also non hi-res amp. with large internal impedance and added series resistors)
Hi, yes,it looks almost the same as the fd5 with just a new cover, but in fact the shell has been changed a lot: improves the wearability by modifying the shape, the angle of the sound tube, etc; the internal design also improves the wearability by changing the front and rear chambers and the shape of the eq.
I mean desired hypotethical product using 2 in parallel thermal-effective (non SOIC) packages of BUF634a (x8 total) in balanced output stage with no addition of serial resistors and no semiconductor mute-switches after BUFs (equipped ES9038pro or AK4499 DACs). That should provide 500 mA continuous load ability and great electrical damping-factor for low-impedance IEMs (and some HP).
