FiiO 2023 New Product Schedule
Jan 12, 2024 at 3:03 AM Post #466 of 494
Dear friend,
Yes, PEQ will be supported in the KA17.
Best regards
Thanks for confirming. Could be a much needed game changer in the dongle DAC space.
Can you elaborate on how the PEQ will work though... Is it entirely software based and needs to be connected to the FiiO app to be in effect? Or do PEQ settings save to the KA17 itself and will be in effect if used on a PS5 for example?
Jan 13, 2024 at 7:54 AM Post #467 of 494
When we seeing the update on these ?
Jan 14, 2024 at 5:01 PM Post #472 of 494
Jan 17, 2024 at 2:02 AM Post #476 of 494
Dear friend,
Hi, 1. You could adjust the PEQ function via the FiiO Control app. The setting will be saved in KA17 after adjusting.
2. PEQ is currently not supported in UAC1.0 mode. So when using KA17 with PS5 in UAC1.0 mode, PEQ is not supported as well.
Best regards
Jan 17, 2024 at 2:05 AM Post #477 of 494
@FiiO are you able to confirm the output Vrms details for the ka17?
Dear friend,
Hi, the output voltage of KA17:
3.5mm output: 3Vrms
4.4mm output: 4.5Vrms
(Desktop mode on, high gain)
Best regards
Jan 20, 2024 at 6:38 AM Post #478 of 494
Jan 20, 2024 at 6:46 AM Post #479 of 494
Fiio also relesed the news page for KA17:
https://www.fiio.com/newsinfo/893398.html
Key Features:
  • Dual ES9069Q Dacs
  • external dedicated Type-C power port
  • FIIO's first USB dongle to incorporate the THX headphone amp circuit
  • THX AAA 78+ headphone amplifier architecture
  • balanced output power can reach up to 650mW + 650mW
  • achieving a remarkable 130dB dynamic range and -120dB THD+N
  • supports up to 768kHz/32bit, native DSD512 decoding, and MQA full decoding
  • supports PEQ adjustment
  • ten customizable frequency bands
  • fine-tune EQ bands, gain level, and bandwidth
  • a 3-stage 10-rail power supply design
  • built-in temperature detection
  • 60 and 120 levels of volume adjustment
  • SPDIF output
Jan 20, 2024 at 12:47 PM Post #480 of 494
Would the KA17 be able to drive a Beyerdynamic t1 gen 1 through balanced output? (600 ohm)
