Excellent Sound Quality Arrives with Purity. FiiO LC-RD & LC-RE Pro Are Officially Released.
Sep 28, 2021 at 7:32 AM Thread Starter Post #1 of 12
FiiO
Sponsor: FiiO
Guangzhou,China
Pure experience with silver——LC-RD swappable plug headphone cable
The all-new swappable plug headphone cable LC-RD is made of high-purity pure silver with high conductivity that not only allows for gobs of detail to come through, but also provides an extremely enjoyable, vivid sound.
Real stuff really makes sense! The LC-RD comes standard with 4 large strands in a total of 224 wires, in which 8 wires are braided together to form 1 small strand, and 7 small strands are twisted together to make 1 large strand. Every small wire contributes to higher electrical conductivity for very finely detailed and delicate sound.
Flagship material- gold, silver and copper braided in one cable——LC-RE Pro swappable plug headphone cable
The upgraded LC-RE Pro consists of three kinds of wires – Furukawa monocrystalline copper, gold-plated monocrystalline copper, and pure silver. All three kinds of wires go through ultra-high temperature continuous casting after secondary smelting to be of the highest quality. As a flagship-grade braided headphone cable, the LC-RE Pro settles a matter at one go.
The LC-RE Pro is always treated as a flagship earphone cable, which consists of 20 gold-plated + 20 pure silver + 20 monocrystalline copper wires. 4 strands in a total of 240 wires achieve better conductivity that presents rich musical details.
In addition, it features twist-lock interchange audio plugs, allowing you to freely switch between 3.5mm single-ended/2.5mm balanced/4.4mm balanced plugs depending on your source.
Specially designed for comfortable wearing experience
To provide a better user experience, we stick to making optimization in every detail. Both the LC-RD and LC-RE Pro are designed with expanded MMCX connectors for reliable connections, and the ergonomic angle makes for a more comfortable wearing experience. Meanwhile, we carefully selected medical-grade stainless steel 316L material for the audio plugs. We care more about comfortability and durability even though the processing is more difficult and the cost is increased. Every choice is for those who are in love with music.
*The LC-RD is available on our AliExpress Official Store. Click the link below to take it home right away.
https://www.aliexpress.com/item/32896656764.html
*The LC-RE Pro is available on our AliExpress Official Store. Click the link below to take it home right away.
https://www.aliexpress.com/item/4000971898372.html
Best regards,
Guangzhou FiiO Electronics Technology Co., Ltd.
Nov 29, 2021 at 3:27 AM Post #3 of 12
Nov 30, 2021 at 4:17 AM Post #5 of 12
Is it possible to buy that black version of the cable seperately?
No, but if you would like to get a black one, you could contact us about that via Aliexpress.
Best regards
Nov 21, 2022 at 4:33 AM Post #7 of 12
Quelqu'un peut-il me dire si les mmcx de ce câble Fiio LC-RE Pro sont compatibles avec les IE 900/600 Seinnheser ?
merci..
Dear friend,
The ie900 is using customized MMCX connector. So our cable is not compatible with it.
Best regards
Mar 20, 2024 at 11:10 AM Post #9 of 12
Best regards,
does LC-RD made from sterling silver 92.5% or its is pure silver 99.999% somethink like 4N silver?
Mar 24, 2024 at 11:07 PM Post #12 of 12
its cheap version 2N only. copper 7N cable for 30eur transmits way better signal
Dear friend,
The engineer told me that it is 4N. And you could try and compare by yourself.
Best regards
