mike1127
Member of the Trade: Brilliant Zen Audio
- Oct 16, 2005
Let's talk about balance in an ensemble with some very low instruments, some midrange instruments, and some very high instruments. Let's say the musicians play a chord with notes from the whole spectrum, and they want it to sound balanced. The musicians will play the low instruments and the high instruments in such a way that there is a lot of energy and low frequencies and at very high frequencies. The design of the instruments themselves reflects this: for instance, bass instruments are usually very large, or connected to powerful amplifiers. If you measure the energy across the spectrum, it will look something like an upside-down F-M curve.
The job of the microphones, recorder, etc. is to reproduce this spectral balance without changing it---therefore they need to be flat. (Exceptions in some cases: see below.)
Or let's talk about a studio rock recording. The mixing engineer will adjust relative balances so things sound "right"--which could mean really heavy bass or brilliant highs--or not---but it is controlled by the mixer.
The headphones need to be flat in order to reproduce what is on the tape. The musicians or mixing engineer is responsible for making that tape. If the style of music is bass-heavy, then the musicians or mixing engineer set that up. The headphone just reproduces it.
If your headphones have an inverse F-M curve they will not sound like what is on the tape.
The exception is: if the mixing engineer uses monitor speakers that deliberately resemble awful car speakers or iPod earbuds or whatever, then you need those awful speakers/headphones to hear what he intended. But this doesn't have anything to do with the F-M curve.
