EMU 0404USB: 1/4 TS vs. Stereo Output - an underrated difference
Feb 13, 2008 at 10:54 PM Post #46 of 49
Originally Posted by penguindude /img/forum/go_quote.gif
- The 176.4 kHz and 192 kHz samples rates are no longer stored on power-off. Now, the system defaults to 44.1 kHz.
Does this mean that it won't be possible to use it as a standalone DAC for high-res?
Feb 16, 2008 at 7:56 AM Post #48 of 49
Originally Posted by thislittlepiggy /img/forum/go_quote.gif
I'm intrigued yet skeptical of the difference between the two outputs. Is there anyone else who can support his findings?
Also, does anyone know where to get inexpensive TS to RCA cables?
There could be a lot of reasons why the 1/4" outputs might sound better. Larger connector surface area, typically larger gauge cable, greater physical separation between channel wires, etc.
You could build your own cables, have someone on the forum build them, or ask a company like Blue Jeans Cable to build them. On a lower budget, use a regular pair of RCA cables and buy two RCA female to TS male adapters.
Feb 16, 2008 at 1:51 PM Post #49 of 49
Guitar Center or similar stores usually carry a brand called HOSA.
