funch
Is earth ground tied to the chassis? If not, you might try that. Also look into a ground loop breaker.
Alternate wiring gave me a huge step forward.
Only a faint hum is left - now equally loud on both channels.
Yet it's there - might an ground loop breaker solve the problem?
Hi,
A couple more suggestions.
1) Look on page 101 of this thread and you will see some pictures of my build. Note that I have only 2 wires going to a "star ground" (from SG on the input connector) and those 2 are going through a ground loop breaker before going to chassis ground.. Mains ground is tied directly to the chassis. Your build has 7 wires. All these are possible points to inject hum into your project.. My only complaint with this amp is that there is too much external wiring to the board.
2) The left 2 RCA's on your build are wired to ground, though the positives are not wired. Try disconnecting those for the time being.
3) Take one channel out of the equation. Disconnect every thing related to that channel. Trouble shoot just one channel at a time. Make sure nothing from that channel is connected. Start from the beginning. Remove all the major possibilities out of the case (transformers, switch wiring, etc). Remove all your ground wiring and then re attach one at a time and in different combinations. Are you twisting your wires? If you are trouble shooting without a source, follow jdkJake's suggestion and short your inputs. Have you tried swapping the tubes to see if louder hum moves with the change? Once you solve the problem on one channel, work on the other.
4) On your next build, mount everything on a piece of plywood and trouble shoot from there. You can see where Stixx and I did this earlier in the thread.
Keep at it, this amp is worth it!
Jim
