HELP - trying to resolve a potential deal-breaker!
The problem (for me) is the bell shape of the Finders earphone; the circumference is too wide, and it's too close to the tip. My left ear canal is shaped in such a way that the edge of the titanium earphone is pressing into it, which is mighty uncomfortable. I've rolled through all of the tips that shipped with the Finders - including the Comply's - and none have provided enough distance between my inner ear and the bell of the earphone. I hope that makes sense.
My last set of earbuds were the Klipsch x10s, which are renowned for their comfort; indeed, I could listen all day and never mind their presence in my ears. Granted, their design is completely different from that of the Finders.
http://ecx.images-amazon.com/images/I/51oCMeOiTpL._SY355_.jpg
Of course, the sound quality of the Finders is leaps and bounds above that of the x10s, so I really want to make this work! Can any of you recommend a solution? I'm thinking my only chance would be to find a longer tip; if I could get a seal in my ear with a longer tip, then perhaps the bell portion of the earphone wouldn't be deep enough inside of my ear for it to cause discomfort.
I would *HATE* to not be able to use these gems. I sincerely appreciate any and all advice that you guys have!
NOTE: This isn't merely a case of me inserting the earphone too far into my ear; I'm only inserting far enough to get a proper seal. This is why I feel a tip with longer reach might be the solution.
