Hey Gang. Guess whut I just listened to? The TK13 and the Easy M2.
Here are my initial impressions:
Easy now has his own boxes little Black Ones just a little larger than the cases (square and triangular) that the earphones come in. They have gold lettering quite elegant and if you are a stacker or a filer there"s a white ID sticker on the side.
Now that I'm done teasing you I guess You guys want to know about the Sound.
IS the TK13 and Improvement over the TK12? Surprisingly subtle but yes it is. First of all the TK13 is quite tip sensitive whereas the TK12 is massive regardless of tips. The TK13 is also massive BUT it has improved resolution and Vocal Mids are WAY better. With the Stock tips, (I tried the Clear/Blue Hybrids), the Bass is Quite Big and very well controlled. NOW, SWITCH TO A WIDE-BORE, (I used my AUVIOS), and the beast is unleashed. The Bass becomes way more prominent at the expense of a little of the tightness. Keep in mind these are OOTB impressions and I expect the Bass will tighten up. BTW, I used a Y cable and A/B'd the TK12 and TK13 side by side, same Tracks. The Bass with Wide bores will make the Most DIE-HARD Basshead smile, But NOT at the expense of the other Frequencies, they shine through as brilliantly as Mr. Z made them to sound.
Now to the Burn In for the TK13, Started at 1:00 P.M. Sat. 4/30/16.....
Lets move on to the EASY M2:
OOTB quite Impressive I went to the Stock Clear/Red Hybrids in the Large size and tried them on....
Jeez. The Chinese are going to put the Germans out of the HIFi business. I was greeted with a very similar sound to the TK12/13 Huge Bass Very well controlled not quite the Clarity of the TK13 but nonetheless still very good. A little recession on the mids and a pleasant treble that isn't harsh or splashy, over all very nice. So I tried the Black nozzles. They are shorter. That's what they do, they shorten the sound. For me they will never be used I might as well toss them.
Once they Break in I think these will be very good. Unfortunately the Auvios won't fit as their bore is a little too wide. I also tried Generic Black silicone tips with a Slightly wider Bore than the stock, I'm just not sure of the difference. well.....
Off to the Burner.
Once again I'm blessed by superb sound. OOTB these are quite High on my list.
TWIN
