kevin gilmore
Señor Stax. Señor MAXX.
Can Jam '10 Organizer
- Jun 21, 2001
OK, so i'm a little busy...
Here is the power supply board REV ZERO. I have not checked this
yet, someone else should. I don't even have all the parts to make
sure they fit in the boards. The board is tight to keep it inside the
20 square inches...
http://gilmore.chem.northwestern.edu/dynahips.zip
you will need a gerber viewer to look at this.
I would not have boards made on this just yet...
not the turkey present i was planning on...
20 square inches...
