Del
well maybe it's a glitch or lil bug on apple music, doesn't bother me at all. for me is a reminder to take a break for a moment.Yea seems like you're experiencing the exact same problem as me but I have no idea what causes it. It sometimes happens with the mango player but never as frequent as on Apple Music. I've checked and yes, I'm able to download my playlists onto my sd card, you just have to dive into the settings and change the download location
If you are concerned about battery life, then either Amp13 or Amp14 would not be as good as Amp11.1S or Amp12. Sound is a different discussion. If you are used to the DX300, you are already losing about 8 hours play time with the Amp11.1 by going to the DX320 with Amp11.1S, and if you are running any of the "Nutube" amp cards (Amp13 or Amp14), those numbers might be diminished even more. Though maybe not as much as it is on the DX300.Unbiased opinion anyone - is it worth upgrading to 320 X with posdibly Amp 14 from Dx300 amp11 mk.1?
Or would it be smarter to get something like Amp12 /13?
Bit worried about much lower battery runtime and well, the diminishing returns.
Another option would be Max, which is tad too big for my use case..
So DX320 even with amp11 will have 8h less than DX300 with marginally / subjectivity better sonic perfomance, am I getting it right?If you are concerned about battery life, then either Amp13 or Amp14 would not be as good as Amp11.1S or Amp12. Sound is a different discussion. If you are used to the DX300, you are already losing about 8 hours play time with the Amp11.1 by going to the DX320 with Amp11.1S, and if you are running any of the "Nutube" amp cards (Amp13 or Amp14), those numbers might be diminished even more. Though maybe not as much as it is on the DX300.
I am speaking in rough estimates here, but yes. The DX300 can last for about 13-16 hours playtime, where the Dx320 can last about 7-8 hours. The Rohm DAC chips inside aren't nearly as efficient as the chips in the DX300.So DX320 even with amp11 will have 8h less than DX300 with marginally / subjectivity better sonic perfomance, am I getting it right?
Uhm.. not sure the upgrade is worth the hassle..
I haven't encountered this issue on firmware 2.07 android, as I typically use 4.4mm low gain as well.I notticed an issue with IBasso dx320 and with latest firmware and with stock AMP card. When listening to IEM's on low volume (below 11 on low gain on 4.4mm) left channel swiches off. I noticed this with U12t and Dunu SA6 on 4.4 and 3.5 mm port and it is similar in both. I notice this fenomenon in Neutron, Mango player and Poweramp in Android. However if I swich to Mango OS I did not observe this behaviour. Did someone else notice this? Should I try to downgrade firmware? Or is there some setting that could be changed?
Thanks a lot. I managed to resolve issue with factory reset. Now it works fine in both OS's and on all players I use.I haven't encountered this issue on firmware 2.07 android, as I typically use 4.4mm low gain as well.
Thieaudio V16 Divinity volume 1-2; Multiverse Mentor volume 3-5; Indigo volume 8-12; Unity 10-14.
I use 3.5mm for FiiO EM5 and also haven't run into this issue yet.
It's strange that your issue is OS dependent, otherwise I would've guessed loose connectors.
For the firmware update, I followed the old instructions: 1x android factory reset -> 1x boot menu factory reset -> update to 2.07 firmware -> 1x android factory reset -> 1x boot menu factory reset -> 4+ restarts.
