DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Jan 4, 2023 at 6:42 AM Post #21,991 of 22,021
Does anyone know if there's a way to put the DX200 into permanent DAC mode? Right now every time I power it on, I have to go in and manually switch it to DAC mode.
I think that's all you can do, that's how I've always done it
Jan 22, 2023 at 12:09 PM Post #21,995 of 22,021
I'm having a strange issue with tidal; via wifi or offline in downloaded mode songs play fine under 'master' quality, but when a 'hifi' song comes up in the que I get the spinning wheel and it hangs. Makes no sense to me! Has anyone experienced this?
Mar 14, 2023 at 4:19 AM Post #21,997 of 22,021
Could anyone please provide updated instructions on how to fully install Magisk? I have resurrected my DX200 after a long time, updated it to latest stock firmware and Lurker's add-on, with a factory reset, but am a bit stuck on how to complete the Magisk manager install. I have installed the latest 25.2 apk of that too. Many thanks!
May 20, 2023 at 12:35 AM Post #21,998 of 22,021
Dumb question of the day: i'm not getting a usb icon anywhere when I plug in the cable to my pc. Going insane. Swiping down I can see all of the standard bluetooth, location services, ect icons, but there is nothing for switching over to file transfer mode. I'm clearly missing something but I have no idea what it is. I've tried powering on while the cable is plugged into the pc, attaching after boot, all the mess. The cable charges just fine so I assume it's not a cable issue (and I have no other cable to test it).
Any thoughts to help a dummy out?
May 20, 2023 at 12:50 AM Post #21,999 of 22,021
On the DX200?
May 20, 2023 at 1:07 AM Post #22,004 of 22,021
I think in settings>connected devices>USB you press on that and pops a menu where you choose charging, or transfering files.
I remember doing that to disable transfering in order to use the DAP while charging from the PC.
Mine was a DX220 but it should be the same.
Connect the usb cable on the DAP first ofcourse.
May 20, 2023 at 1:08 AM Post #22,005 of 22,021
Btw, you have to be in android os and not in mango os, you know that right?
Yep, i'm in android. Appreciate the help.
USB is greyed out in the settings page, even though it's connected through usb. Good times. Still investigating.
