Spad
- Dec 11, 2001
Actually there is a reason. I wasn't trying to do an indepth comparison of the headphones, just a quick-and-dirty head-to-head out of idle curiosity. I had compared them to my satisfaction previously, so I was really just doodling around.
As you likely know, it's vitally important when A/B-ing components, that volumes be matched as precisely as possible and switches between them be made quickly. Because the EJ1000's remote functions while the line-out is in use, I was able to easily set things up without even leaving my recliner. (A major consideration in all my 'scientific' endeavors.) Since the CD3Ks sounded better even when driven from the PCDP's headphone output, there was really no reason to switch them to the META. Had they sounded worse, I would have made the switch to determine what role the amp played in the outcome.
This, if anyone reads between the lines, is actually more about the impact of their relative sensitivity than the sonic merits of either headphone. The point being, of course, that the CD3000 can be driven to more than adequate levels even from the latest (read 'wimpier') PCDPs. So perhaps, all things being equal, headphones with higher sensitivity ratings are inherently better choices.
Originally posted by FCJ Spad, Any reason why you didn't use the Meta with the Sonys? |
