rodgerdodger
- Jul 23, 2016
Anyone done voice coil repairs before?
One driver has snapped coil under the diaphragm just on the edge. Used skippies method to remove the diaphragm with a pin around the edge bit by pit, time consuming but it does work.
Now i have 2 choices,
1 attach on to the existing voice coil wire on the edge of the diaphragm , which will be hard, would require striping back the existing wire with acetone etc and joining an extra length...somehow
Or
2. removing a loop from the central voice coil as others have mentioned, this concerns me as well tho as the 2 voice coil wires are glued with a tiny black spot of glue so if i did remove this unsure how what glue id use to spot glue them back, i guess the same glue that i will need to glue the outside of hte diaphragm. But not sure if that is actually needed. Also second concern with this is im sure this would alter the sound signature in someway.
Ill post some pictures of what im dealing with later. This isn't a must fix issue, its just more of a challenge
Or
