edwardsean
- Jul 7, 2006
I recently wired a balanced cable but I think I may have gotten the positive/negative leads mixed up on both sides. The thing is I like the sound better than if I switch the leads back the other way. It sounds more open and correct to me.
Since the negative and positive signals are mirror images does polarity matter if both sides are terminated with the the same positive/negative assignments? If it does matter and I inverted the polarity am I preferring a compromised sound?
Thanks!
Thanks!
