renji1337
- May 27, 2011
I have coiled my cables like this.
Will this harm the cable or the sound quality?
I would have thought this would be a common sense thing, like not shoving a paper clip into a live wall outlet.....
It's not a dumb question. A transformer is basically two coils placed in close proximity so that one coil is within the electro-magnetic field of the other. So it can actually make a difference.there are variables to consider such as the number of turns ,(loops) and the amount of current. For headphones the amount of current it's small so it's hard to notice but I have noticed that sometimes a difference which is nearly impossible to can contribute to listening fatigue. I do coil my cables but not that tight. The tighter the coil the more "turns" you will have. Even if there is no other coil nearby the conductor still must contend with its own field. An inductive field is like adding a resistor to your cable. I'd loosen it up. The tighter the cable the worse the effect. And make bigger loops.
And regarding eee pee's photo, that cable looks great for a Bose system. Or maybe Beats.
