Omnirai
- May 1, 2011
The Ipod Touch (I use a 3G, but the same applies) is a fairly competent music player - at the very least I won't blame it for the underwhelming sound that the OP seems to be hearing. Stock ibuds to W4 is an extremely big jump and I cannot imagine anyone not hearing a significant difference - the problem could be source (as in, poor quality rips which can easily sound worse on quality gear than it does on ibuds), fit or just that the OP was expecting a completely different kind of sound.
If the W4 still doesn't impress after so long and you are sure it's not a problem with source or fit then it simply isn't for you. That's OK - the W4 are amazing cans but I prefer many other less pricey models to them as well - all preference. I suggest you return them and go a little lower on the chain to find the type of sound you are looking for. Don't give up on this pursuit is what I can say - when you find the sound that is for you the audio heaven is very rewarding. No one who wants to appreciate music should be stuck doing so from ibuds.
