Steve Eddy
Member of the Trade: The Audio Guild
Aka: TempAccount555
- Sep 28, 2003
So much for anonymity..
Dude, I'm sorry. I've deleted the post.
se
se
Again, can you feel a pea under ten mattresses? Just as measurements are limited by the resolution of the measuring equipment, so too are cables limited by the resolution of the headphones or speakers. If you're connecting a $50 DVD player to a $150 A/V receiver and some cheap bookshelf speakers, don't waste any money on cables. I'd be the first to tell you that. You could spend tens of thousands of dollars on Siltech Royal Signature for that system, and you'd hear no difference. The equipment simply couldn't take advantage of it. It would be the same as strapping a $2K piece of Canon L glass to a cellphone camera. Kind of dumb.
Though I don't always follow it, generally I think the "20% rule" for cables is sound advice. Spend 20% of the price of the equipment on cables for that piece of equipment. Thousand dollar amp? Spend $200 on interconnects. Where you put that $200 of course makes a lot of difference. Signal Cable's $100 Silver Resolution will beat up $200 cables from most of the big brands. One should always spend wisely.
If you have a $60 MDR-V6 and you follow the rule, that leaves $12 for a headphone cable. So.. don't bother.
.... Let me use YET ANOTHER analogy to see maybe if it seeps in this time. Let's say you're trying to judge differences between pro grade Canon L or Nikkor FX lenses...
Do you understand what I'm saying here?.
I know how to calculate electron drift velocity, that's not the problem. I just remembered it as centimeters per second instead of hour.
has anyone used the stock cable of a headphone, taken the frequency response, then used a really bad cable and then tested the frequency response and then an expensive cable and check the frequency response???
cheapskateaudio did a measurement of stock vs. silver aftermarket cables with his HD650 that showed differences, but he never reciprocated to requests for repeated tests.
"reciprocated to requests for repeated tests" say that 10 times fast.
I find it interested that we use the term "high end" when what we really mean is more expensive.
Better material does help and so better material will cost you more then yarn.
Read in this web site. I myself have bought many earphones ranging from $150 to a little over $1,000 dollars and when I replaced the stock earphones it did make an improvement. Also there are some users on here who has spent over $8,000 Dollars of just In earphones who have also tried the better material (Silver) cables and they also agreed.
