Amplifiers (in general) do not come with built in sound cards.
Please provide the details of you current setup, maybe someone on Head-Fi can figure out how to improve your audio quality.
Sometimes you can use your current built-in audio features with an external DAC/amp.
As the motherboards come with DTS audio, it might be better to hook up an external DAC/Amp to the S/PDIF Toslink optical output on the motherboard.
Use the motherboard's built in audio functions (DTS), but use a better DAC & amp for the headphones.
does the p8h77-i also come with dts audio? that will the mobo i will most likely buy, since it is $100 cheaper
i couldn't find the internal sound card specs for the p8h77 mobo (the cheaper one, costs $99)
