I've been happy with the stuff I have gotten from this shop: http://stores.ebay.com/applecable?_rdc=1
DIY OTG Micro USB B cable to USB B Tutorial
- Thread starter FraGGleR
bapspidoff
- Jun 27, 2012
does anyone know where you can buy these online? it's proven pretty hard to find...
Buy what specifically? There are links to the parts in the thread. If you are looking for finished cables, there aren't many/any hence the DIY nature of this thread.
bootdsc
- Aug 3, 2011
FIIO has a good selection of oddball cables but no micro b to b I'd like to see if a usb printer would work straight from my phone, I know it has the drivers to work over wifi with most printers would be a interesting experiment. Lets see if i have my otg cable handy.
h1f1add1cted
I would buy instantly such nice cables. But I have two left hands to build my own cable. I looking since ages for a USB mirco-B OTG to USB B-type cable for my Android device, I only found a expensive (really good looking too) from Forza AudioWorks.
Muffin860
- Dec 4, 2014
- Thanks for this FraGGleR!
I used your tutorial to make my first OTG cable. It was my first time using epoxy putty as well; had no idea it'd be so sticky.
It ended up being a little too long, so it's gonna bother me enough into making another one soon.
Can you explain your pinout? Was their any difference since you went 5 pin to 5 pin? Would I use the same connections for a Micro to Mini OTG? Thanks!
money4me247
- Jan 27, 2013
Anyone know if there is a pre-made OTG usb with a similar short cable length with male micro usb to male type B usb? links or referrals to customs cable companies would be greatly appreciated.
Very nice tutorial!
Thank you!
Thank you!
esteboune
- Jun 6, 2015
Hi guys!
Thanks for this good tutorial
i would like to do a LOD cable as follow
Sony ZX2 to Alo audio CDM (USB in)
so it is a Walkman port to a Micro USB
on the Walkman side, no problem:
D+, D- and ground
but what about the micro USB side?
do i need to solder the Sense to the GND?
what about the Vcc?
Thanks a lot!
D+, D- and ground
what about the Vcc?
Here are two images that should help:
I am always an advocate of DIY when there is opportunity. Happy to help if you give it a shot and run into questions.
Thanks a lot!
agzerx
- Apr 5, 2016
This topic is old, but talks about the OTG cable, so...
Guy... i was think... if the Micro USB B to Micro USB B ( otg ) from moon audio ( copper and silver ) have some difference on the quality of the sound that i'll be pass to the Chord mojo?
Because... i have a "normal" micro usb b to micro usb b ( otg ) that cost me about $10, so... on the moon audio have the copper over ( $85 ) and the silver over ( $110 ),
so i really would like to know if some one think or have made some test to determinate if have any difference or not ( on this connection between the Phone ) to the Chord Mojo with this kind of cables.
( i already i'll use the silver dragon cable shure v1 on my se846 ), but the ( OTG silver or copper ) i dont know if wort and i'll have much difference or better results then the default ( normal over $10 ).
Im not judge by the price, if have a great difference so, its justified!
Wait some helps guys!
esteboune
- Jun 6, 2015
This is a very tricky question you are asking Agzerx!
First of all, i do believe quality cables are worth it. I do hear a difference using silver / pure silver cable with my various IEM or full size cans.
However, we are referring to an analog signal...
Now regarding USB cables, it is digital signal: 0 or 1 to simplify.
So to rephrase your question: How can silver cables alter or enhance a 0 or a 1 ????
agzerx
- Apr 5, 2016
I got, so... as dont have any difference using pure silver from Phone do DAC, right?
WayTooCrazy
I don't see how such a short run would make any difference.
Ciuvn
- Apr 26, 2013
is that ok if I use both side is micro usb and both active OTG function? ( solder both side pin 4th and 5th)
WayTooCrazy
I do not think it works that way. Only 1 side should be setup with OTG function. The other should be setup as a normal USB style connection. Yes, they can both be MicroUSB as that is how I've done it when I was using an external DAC.
