tvr2500m
- Mar 2, 2009
Just to give it a try, I grabbed a little Musical Fidelity V90 BHA balanced headphone amplifier. I'd like to try it with its balanced output. It is fitted with a 4 pin mini male XLR jack, requiring a cable with a female connector termination on the headphone cable. My Focal Elexes came with a balanced cable: a pair of 3.5mm TS at the headphones end and a single standard-sized male Neutrik 4 pin XLR at the other end.
I'm not at this point committed to the MF V90 BHA. Rather than spending the $50+ dollars for a new cable terminated with a mini 4 pin female plug, and since I do have an XLR terminated cable, I would make an adapter. Just a mini 4 pin female XLR to 4 pin standard female XLR connected with four runs of 24'ish gauge wire courtesy Belden, Canare, Mogami, etc. MF supplies the pinouts in the amplifier manual so I know how to connect up everything.
I have some questions. It seems kinda easy. Just straight up connect the same terminals between the two connectors per the MF wiring diagram. I could even get a little spiffy and braid them like some Kimber thing.
The question I have is about the shielding and drain wires. What do you do with them? Ground them somewhere? Leave them alone? ???
Thanks!
Thanks!
