cdacosta
Crystals update...
I believe that experience is gained by doing and this process is slow. I also believe that one can speed up the learning curve by learning from other's experiences, like from Entreq and in this case Tweek Geek. They state from their testing, streaming is very effected from crystals. I really expected a lot of experimenting but the first thing I tried worked really well. My internet is from Comcast, which is cable based. There is a cable output at the wall in my office. I placed a small rose (strawberry colored rose to be exact) crystal on the top of the connector at the wall, held down with masking tape. The crystal is directly touching the connector. The mid range and mid bass got thicker, warmer and lost some resolution. Then took a small white or clear crystal and using masking tape, placed it on the bottom of the connector. Exactly opposite side of the small rose crystal. Important that each crystal is small like 8mm or so wide and long, with one side being fairly flat so it can make enough contact with the connector shell. if the crystal is too large or thick the effect is too strong, sounds odd with the overall presentation sounding imbalanced. I would bet different sized crystals would yield differing results.
After adding the second crystal (clear) the effect changed from the rose crystal first installed to more like before/without the rose crystal. But with a thin layer masking what is heard being removed. Now the presentation sounds even more spacious and with a bit more precision in the presentation. Kind of hard to explain, one has to hear it to understand. I did this last night. I think it sounds better now than last night, likely needed time to settle-in. Definitely like what this did. The change is almost as impactful as changing a cable. I would wager that different crystal types/colors will again change the overall presentation. I will experiment further. This is definitely interesting. Pic is of an example of the crystals I used and the sizes I used. Not ground box related but this tweak definitely works well with everything else in this thread.
