bigalila
- Apr 20, 2012
Thanks for the link and info! With the DIY Manufaktur name on the thread I was never going to find it! Thanks again!!!
I'll post pics, unless I botch it, then I'll act like it never happened.
Open to all recommendations!
Thanks!
You can buy single conductors, but typically it's more expensive than Mogami quad. Redco, SonicCraft, Double Helix, Blue Moon Audio, etc, all sells this kind of wire. If you're making a single ended cable, not having a shield can make your system more prone to interference. I have one and I have to move my cell phone away from the cable, or I can hear the data transmission.
Right, but how do you split the shield at the separation point to go to each side? I guess you can rewrap the shield arround each side?
Just strip the inner conductors out, forget the shield. Shielding isn't useful for headphone cables.
When it comes to shielding on headphone cables, I feel the added flexibility of having a cable without a shield outweighs any problems I might have with interference using it. None of my cables have shields and I still don't have issues with phone signals, or anything else.
I am planning to build 2.5 mm Trrs to shure plug IEM cable for JVC 850 balanced cable. I found this awesome 2.5 mm trrs plug with lock in ebay. But very costly 35$, http://www.ebay.com/itm/Original-Ranko-Acoustics-REP-1050-4P-Rhodium-Plated-2-5mm-TRRS-Stereo-Plug-/321646170681?pt=LH_DefaultDomain_0&hash=item4ae39b1239
Please suggest 2.5 trrs plug with lock, for around 10$
