White Lotus
Reviewer for Stereo.net.au
- Mar 10, 2010
I have some Lohb cups that I might look into tuning. What's the best way of doing this? Dynamat on the inside of the cups?
I have two sets of deep Lohb cups, one on my LA2000 and one on my LA7000. For me, the combo of the Lawton tuning and angle pads is simply stellar. For the cups, this consists of a sticky disc and a foam pad that then sticks to the disc. The deep cups with this damping plus the extra distance to the ear from the angle pads is (for me) magical. Below is a pic of how the damping looks in the stock D7k cups, which I have available for a photo.
Hope this is not out of line, but when I had my wood cupped d2000's I had some Mr.speakers alpha pads on them and really enjoyed them. I have since sold my d2000 but forgot about the Alpha Pads that I still had. I have nothing that they really fit right now so they are up for sale in the accessories section of the want ads. The alpha pads increased the comfort, and the seal was great with them.... And cooler on the ears. PM if interested.
James
I like the Alpha Pads on my D5000k, though I prefered the Lawton Pads after a while as they were a tad drier overall, still i've got Mr SPeakers pads on my TH X00 and I realy like them
my only issue though is FIT xD the Lawton pads have more room, when I have more hair
I thought all true headphone audiophiles shaved their heads?
NOTE: Pads normally come off very easily using the pinch and twist method. There is a small percentage of these plastic rings that can be a little more stubborn than others. For these cases, use caution and make sure you do NOT overly stress the teeth by pulling up on them too hard.
TIP: For these unusual cases, simply peel the pad itself right off the headphone, separating it rom the plastic ring, leaving the ring attached to the frame for now. This will not harm your pad, it will slide right off the ring. Then using a screwdriver with a flat head, push firmly against one of the teeth in the counter-clockwise direction toward the larger end of the slot; the ring should now free itself.
Hey guys, I used to lurk HF a lot, but I haven't been on here in a long time.
To put it simply, I have a D2000 that I got in I think 2010 or so, new in box at the time. They've gone through some of high school, and almost all of college now. However, this has taken a serious toll on their condition. Short list of problems is:
Flaky ear pads
Worn cord
Rubber reinforcement for cable entering cups has come loose
I think the headband is flaking
Scratches on cups and metal parts
They have no mods, they're just worn from daily use, travel, etc, over the years. I'd love to work on restoring them. I know the Alpha ear pads are mentioned, and the price on them is not bad, but which are the correct pads? I see Alpha makes a few different sets, I'd hate to order the wrong one. I'd like to recable with a 6ft length. I was thinking of the MarkL mod on the stock cups, and then potentially looking later on at getting some wood ones. I'm also thinking about possibly anodizing the metal parts, has anybody done that, or found a way to cover up the scratches?
Thanks!
These are the Alpha pads I've been using.
https://mrspeakers.com/shop/3-accessories/alpha-pads-genuine-lamb-leather/
Very soft and durable. I'd recommend them.
Anodizing won't cover any surface imperfections, you will have to strip them down, sand, and repaint. The Krylon Fusion paint works great with acrylic clear coat to protect it.
You can also do the EZMods for the TH-900/TH-600...mainly use the paper tape to help dampen the cups and driver surfaces.
http://www.head-fi.org/t/802704/th-900-fostex-ez-simple-mods-and-other-fostex-dynamic-variants-x00-denon-more-bass-mid-soundstage-smooth-trebles
I don't know if you could find them now, but the pads I switched to a while back were the J-money Lambskin pads, which are just a little bit thicker than stock. Whatever pads you get, lambskin is probably your best material choice.
That looks awesome, how'd you get the female connectors? I only see male connectors on the MrSpeakers site.
