The Puddle
- Mar 11, 2015
A FiiO E10K should also be just fine.
Your not going to find a huge difference in sound at that price. Some will be a little better than others but not that you can tell a huge difference. Some like one and not the other as you might like the other. You should go for what you thought you should go for the first time you started to make a choice of what you wanted.
Hm. What if I get an ODAC and bypass the Omni's dac and just use it as an amp? The Omni supposedly has a 3.5mm input. Would it be PC > ODAC through USB > Omni through 3.5mm? And another USB to the Omni for power. I just need to set my audio device to the ODAC in Windows, right?
I use a k7xx with dolby headphone dh1. It's actually one of the best headphones to use with virtual surround sound. The issue with stereo, for gaming, is that sounds like gunshots are ambiguous in terms of whether they are coming from in front of you or behind you.
I did consider that option but did not think it would get as much out of the cans. The only virtual surround I've used is the Dolby headphone built into the mixamp but I'm not a fan of it vs the stereo sound. Stereo sounds much cleaner and easier to pinpoint things to me. Would the sound blaster z DAC be as good as sub $100 external DAC if putting it to a magni 2 uber? I wanted to keep DAC and amp around $150 or so but am considering spending a bit more for the Magni 2u for the preamp outs... I guess I'm wondering how much difference am I going to notice between something like a SD793-II,SD-192 pro, sound blaster z, etc for use as a DAC vs getting a modi for roughly double the price? Sorry I'm a bit new to the headphone area
You can get a Bravo Ocean (with pre-outs) sent to your door step for $120, then use whatever is leftover in your audio budget for a DAC.
Used Asus Xonar DX or D1 sound card (same DAC chip (CS4398) as the SB-Z).
Hifimediy USB DAC, $30-$70
That may be what I end up doing. I appreciate the advice a lot, thank you. Probably end up with a DX or sbz with the Magni 2 not Uber though. I've looked at tons of comparisons of the sbx and DX and am having a hard time deciding. I am not really a fan of Dolby headphone as I've stated so I may try the sbz just to see if that surround is any better to me. Anyone know the stereo sound difference between the sbx and sbz if using an external amp? Also, would the sbz having the separate front speaker out vs the headphone out be better for running to an amp?
