Patrick82
Banned
- Mar 1, 2003
I tried SACD and it sounded the same as Redbook CD, it is probably because of my Magix levitation feet which makes Redbook CD sound very smooth. Maybe Magix converts Redbook CD into SACD!
All my reference classical SACD albums sound very bad, I think it's because of bad recording gear. I bought the same albums as all the reviewers use and the quality of those albums haven't improved much in a couple years of tweaking my system. They are only "high quality" when a single sound is playing, but when there are many sounds playing at the same time they blend together and it gets muddy. Trance music doesn't have this problem because all sounds are mixed together. My 192 kbps trance mp3's from computer are higher quality than classical SACD from my dCS system.
It appears that the Firewire noise from Verdi CD transport compensates for the muddiness of classical albums which makes it appear more transparent. It's similar to using Valhalla interconnect or speaker cable to add fake transparency to the sound. But when messing with the sound it removes low-level detail in the process, I don't like that, I might as well use Toslink from the computer instead because it sounds cleaner without that noise. However, Toslink has more jitter so it doesn't get any better, it only changes the flavor.
dCS should build a new setup that uses an optical connection. In the mean time I will unplug the Verdi and use my computer + Toslink because it gives cleaner sound and more jitter. A transport with an electrical connection isn't worth anything to me, no matter how little jitter it has. I don't think anyone wants to buy my Verdi after reading this thread so I'm going to try a Genesis AES/EBU cable to see if it fixes the noise.
Originally Posted by tourmaline /img/forum/go_quote.gif The complete dCS system is one of the best on the market and best sounding systems you can get. But at almost 50.000 dollars/euro's not much people can afford it! |
