@sheldaze
That's interesting as Jan Meier himself in the thread said the Rock was warm for not so great recordings (what I listen to) and others said "neutral-warm" compared to the Magni's "neutral neutral to neutral bright". He also said that the warm Rock + the 600 (warm mids, ever so slightly bright treble) is still warm and relaxed. If the Element is much warmer than that who knows what nwavguy and JDS Labs mean by "a wire with gain" or "objectively neutral"! I'm going to order the Schiit ubers as I already think the HD 650 + O2 is dark enough/needs ever so slightly more high end air but not enough to do a mod.
Schiit Uber - everything powered by A/C. Sounds like a plan
![beerchug.gif](http://files.head-fi.org/images/smilies/beerchug.gif)
Looking forward to hearing the stack, in its entirety, at the next meet! I've heard pieces of it in past...
EDIT: I like the idea of an upper limit to the cost of the products in the mini-meet. What cost would it be though? And I'd prefer if you separate the headphones from the AMP/DAC. Say $500 for the AMP/DAC and a separate $500 for the headphone. But it's up to you! I'm down for the idea!
EDIT: It is possible The Element is less warm then the Rock. However there is a clarity or sharpness to the sound coming from the Corda Rock which to me makes the sharp, attack sounds more noticeable. Things like the drum sticks hitting the metal part of a drum (sorry, don't know the name - it's the outer edge, raised part) is much sharper and faster on the Corda Rock. It's less focused on The Element.
