Originally Posted by BIG POPPA /img/forum/go_quote.gif
It won't have a softer presentation. I forgot to mention that the wall receptacle is an Oyaide R1 and with the SR it fixes the decadent sound of that. The sound I have with my 336se is pretty awesome. Just have to tweek the last 1% with some tubes. Tube roll, fuse roll, powercable roll. What next?
Maybe "softer" wasn't the best adjective to use. The RCA 6AS7G grey plate will bring expansiveness and a nice, open midrange, but bass will not be as prominent or punchy.
Try taking the power strip out and see if the bass comes back. Some (active) power conditioners can rob your system of dynamics.
What next?
(1) Try some tube dampers. Herbies damping rings work well; the Duende titanium/teflon rings work even better, I think. You can get heat resistant "o-ring"-type dampers cheaply on e-Bay, and they work fine, too, for the price. Some damping, I think, can be beneficial; but you can overdamp tubes and deaden the sound, too.
(2) Try isolation/vibration control under the amp. I used the Herbies gabon ebony Domes to good effect, or DH Labs cones.
(3) You can make a platform with five Vibrapods, five racquet balls and a piece of 3/4 inch MDF board on which to place the amp. I call it the "Cloud Nine-to-Five" DIY platform.
(4) I've also made small wooden boxes, about 2 inches deep, open at the top, and filled and levelled them to about 1.25 inches with fine sand. Cut a piece of 3/4 inch MDF to fit inside the inside dimensions of the box (offset about 1/8 inch in from all sides) and place over the sand. Put the amp on top of the MDF. This is one of the most effective and least expensive isolation platforms I've ever used.
If you have a CD/DVD player as a source, then isolate it first, since it should benefit most from isolation/vibration damping.
PAB
