I must add that the result is incredible...Sorb under the feet of the energizer and new pieces of semi-spherical cone sorb under the feet of the Sansui au-7700 amp (no need of bricks for the Sansui
Here under the amp i had the inverse problem: the 4 too much stressed little square pieces of sorb i replace by the 4 more thicker cones)... I dont recognize the soundstage now (more detailed depth in fact )... Ok perhaps it is a bit exagerated i recognized it, but it is imaging more clearly now , hence the better improvement is there ... The soundstage was the last minor limitation of an otherwise ultra high end headphone : the Stax SR-5 , and now cured with the brick+sorb mods.
i think that the soundstage is a very sensible information resonant virtual space that is constructed by very sensible tiny bits of sound information frequencies, very few vibrations may blurred all that, hence the potency cure of the sorbothane in this area...How lucky we are to have stumbled on this thread in the first place...I have said it already, for me this thread is the most important thread in headfi...thanks Edstrelow
update: after few hours of listening, i must say that i had not exagerated a bit in my first impression, 2 bricks and 8 pieces of sorb made magic come true...(10 pieces of sorb 1/8 inches 40 duro under each pads and
4 pieces of semi-spheric cone sorb. -50duro- under amp in replacement of my too stressed 4 little squares and 4 squares pieces under the energizer with 2 bricks of working load for a more efficient damping on the srd-6) and i dont recognize my sr-5 anymore, chokingly good...
It is impossible to exagerate the profits and advantages of a rightly made sorbothane application , the recovery of sound qualities with my so call "obsolete" headphone and their transformation in high end products cure definitively upgraditis for me...
p.s. remember to put 4 pieces of sorb. under your dac with an appropriate load on it to made the weigh ideal for the absorbing sorb. it made a subtle but clear difference also...there is a marble plate with 2 little amps on top of my dac, hence the weigh is optimal for my 4 sorb pieces of 50 duro...
final update after 8 hours and the 2 bricks + the sorbothanization of the energizer and the dac and the amplifier: the sound is now not only clear on all frequencies , the sound experience is now totally IMMERSIVE ...it is like any sorbothane correction of all the pieces of gear added one by one to the sum total: immersive musical experience for the first time in my life with an headphone, my audiophile speakers are crushed by the Stax SR-5 already...
the lesson learned is this : if the load is too light or too ponderous on the sorbothane pieces, that will not work so good...
Some people will say that i exagerate the impact of the sorbothane on the Stax SR-5 sound... i will be clear : there is absolutely no comparison for me between the sound of the stax SR-5 before the application of the sorbothane and after it, and with the right application of the sorb. under the energizer, the dac, and the amplifier...
NO COMPARISON.
