cucera
- Mar 11, 2013
I can report a clearer sound and dryer bass with the Stax 4070.
very interesting read Edstrlow. Thnx a bunch for sharing.
In rgrds to the Sigma's, have you considered placing the sorbotane on top of the driver? (the side that faces towards the inside of the housing, and on the inside of the side facing the head (or hole to the ear)?
As far as I remember from doing the 404 upgrade, there are some space around the driver that is stuffed with glass wool. (I might remember wrong though)
Another thing is the 007 ... have you considered damping the top mess? the part that is covered by the earpads ... or would it just be crying for trouble?
Hi Edstrelow
Again thnx for sharing your work and impression.
I have taken the liberty to work a bit on one of your photo's in order to visualize what I had in mind (it still may not work, or simply being pursuing other kinds of problems)
I can't figure out from your description whether you have already done damping the BLUE area on the 'vertical' part using the stickers you have designet.
The BLUE and GREEN area on the driver itself could make a difference?
Finally the RED will involve diassembling the protection filter and damp the stator ... there might not be enough space, or it is simply crying for trouble doing so ... was just inspired by some folks experimenting with full size ESL's where they do something like that.
Anyway I just wanted to share my thoughts on your brilliant work, and look forward to hear comments
Yes I put sorb on the blue, vertical sections. Sorry if that's not clear in my description. The green and possibly the other blue sections might work too. I would be loath to do the red just because I wouldn't want to mess with the dust covers, but who knows? I do not contend that I have exhausted examination of this topic. There are potentially a lot of parameters to play with here: location, hardness of sorbothane, attachment and clamping. I still like my first clamp on the 007 headband because it allowed some tonal adjustment. Plus, based on my experience of bad bass on some attempts, you apparently can also screw the sound up, suggesting positive feedback messing up the sound.
So you say someone has tried damping electrostatic speakers with sorbothane? No reason why not, I have put some on my conventional speakers.
Just to be absolutely clear: I really appreciate your effort and work in this area, and that you are sharing - it is a great inspiration, at least to me )
In rgrds to damping ELS's with sorbothane; I am not sure about the use of sorbothane, although I have read a few places that damping the stators makes a difference.
[url=http://www.eraudio.com.au/Loud...speaker_Kits/Acorn_ESL_kit/acorn_esl_kit.html[/url]
Stator Damping
Thin metal stators tend to “ring” when producing sound so it was important to provide some damping to the grid to deaden the colouration that would occur. This is especially important where large areas of unsupported stator are exposed.Fortunately, our experience with the ESL III and the use of a polyurethane material, which gave superb damping in this speaker, was very successful in stopping ringing. We have therefore adopted the same material and method in this design.Never tried it, so I cannot comment on the effects.I guess doing it on the Lambda drives will need a spacer between the driver and the protection film and it might incure other problems due to the surface the damping occupies.I have ordered some sorbothane from: [url[https://www.divineaudio.co.uk/audioquest-sorbothane-self-stick-sheet [/url] ...I will try damping my Sigma/404 and see what happens and report back afterwards.
