Hello!
I currently have 2 x KRK 8 INCH monitors hooked up to a Creative XFI 5.1 USB sound card. (https://us.creative.com/p/sound-blaster/sound-blaster-x-fi-surround-5-1-pro)
The speakers are connected to the USB sound-card using RCA to 2 x TRS cables.
I'm looking to buy something "better" and use balanced outputs.
I was thinking of Audient ID4 MK2 - https://audient.com/products/audio-interfaces/id4/overview/
I was also looking for a DAC - https://ifi-audio.com/products/zen-dac/ but the balanced output is 4.4mm and it is very hard to find a cable from 4.4mm to 2 x XLR. Also I try to avoid adapters...
Now, for the questions...
1 - Will there be any improve in sound quality?
2 - Will the maximum volume be higher?
Note that I mostly listen to Youtube / Spotify music.
Thanks in advance!
Thanks in advance!
