Yes, This is exactly what I am looking for, a bit pricy though. How did you make the choice to order it? I would be interested to know your feedback.
It's complicated...
I started building my own speakers a while back, and now in my living room I am experimenting with a new open-baffle speaker setup with high-sensitivity drivers. I really love it so far, super clean, very dry and clear bass response. The problem however is, that open-baffle speakers need to be equalized below the "dipole-peak", which is about 240 Hz for me. Further, this system is also an active 3-way, meaning I have an active crossover and three amps for low/mid/hi. As you can see, in this case I am not even too interested in the headphone output of the RME ADI-2 Pro, even though it's supposed to be very good.
Considering that setup... I like the RME ADI-2 Pro because...
- Most active crossovers have balanced inputs, so having a pre-amp with balanced outputs just makes things easier
- It has a 5-band parametric EQ, which will allow me to do the equalization my open-baffle speakers need.
- It has analog
and digital outputs, so I could use e.g. a DSP-based amp, feeding it the digital signal, and analog everything else
- I really like the implementation of loudness in the RME ADI-2 Pro. It's a scientific fact that we hear less bass and treble detail at lower volumes, so a sophisticated loudness option makes a lot of sense to me
- Everything can be controlled from the device itself; I don't
have to connect a PC to control it via software, which some Pro USB DACs require
- It has plenty of inputs, including analog ones, so I can connect my phono stage to it
- It's USB connection works both ways, so you can use your computer to record analog sources through it
- Objective reviews (those that actually measure devices and judge the results) are very positive
- It's made in Germany... like me
Disappointing is the 6 month warranty. I know today you often don't get more than 12 month, but it just doesn't scream confidence. However, if you order it from
Thommann, you get 3 years, it's just what they do with everything they sell.
http://thomann.com/
Shipping takes a bit... but I will let you know more when I get it (what exactly do you want to know?).
It's worth going through the manual, it's bloody long and really shows you all the features it has, and lots of scientific insides, too.
With all that said... I really hope the RME ADI-2 Pro will live up to what it promises. Either way, I will report back here.
Cheers,
DrTebi
